Design Options issue
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
emmanuelbee
2241 Aufrufe, 6 Antworten
what does the 'active only' checked box do in design options? I thought unticking it would show the other option that you have in your design option but it doesn't, whether i leave it ticked or not ticked nothing seems to happen so what is it there for? I would like to be able to copy and paste a few elements from my other option and i don't want to keep having to change views to do it, it takes too long
6 ANTWORTEN 6
Nachricht 2 von 7
Avaris.
als Antwort auf: emmanuelbee
Exclude options is only to be able to select the items that are in a design option. e.g. the elements of the primary option when in the main model.
So yes, you have to switch between:
-design options
-views wherein VG a design option is selected
Nachricht 3 von 7
emmanuelbee
als Antwort auf: Avaris.
So what does ticking or unticking the active view do?
Nachricht 4 von 7
When you choose to edit an Option, tick the Active only will not let you select and edit any elements outside of the Option, including the Main Model; untick it will let you.
Nachricht 5 von 7
emmanuelbee
als Antwort auf: ToanDN
That's the problem that I'm having, when i untick the 'active only' it doesn't show my other option
Nachricht 6 von 7
You cannot show elements of different options withij a option set concurrently.
Nachricht 7 von 7
emmanuelbee
yes I've just realised, it seems you can only show elements in the main model within your option set
