My team is utilizing the design options feature to explore cladding concepts without modifying the main model. As we know, Design Options has its own set of graphic properties. After printing a test PDF set, I am not satisfied with the Elevation view that is being output, and you can see in the screenshot that the preview of the sheet in Revit is different than the PDF output.
How can I adjust these line settings to darken project geometry lines?
Thank you
Sorry the post wasn't so clear. Let me rephrase:
I have since accepted the Design Option into the main model, so there are no longer any active design options in the project. Thus, the VG settings are not impacted by the Design Options anymore.
Here is a snip of one of my drawings:
Revit assigns objects that are set back further from the primary plane to a lighter color line stroke, it seems. Is there a way for me to adjust these lines both in the main model view, and, for next time, within the Design Option?
