Design Option Room Schedule
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
IMCornish
2107 Aufrufe, 8 Antworten
I am currently working on a project with two design options which each require their own Room Schedule however, despite the guidance, in the help menus, it does not appear to be as an Option View which can be controlled by the Design Options tab of the Visibility/Graphics dialog of the view since when viewing such with a schedule the 'Design Option' drop down is set to Automatic and cannot be changed.  Am I doing something wrong?
Andrew Robertson
Chartered Architect
Robertson Partnership
Truro. UK
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: IMCornish
You should be able to do it.
Nachricht 3 von 9
Are you saying that you cannot change Auto to the DO you want to schedule under the VG Overrides in the schedule  itself?
...if this is the case,  you might check your Phase Settings in the Schedule.  Rooms are "Phase-able".
Nachricht 4 von 9
View template assigned to the schedule?
Nachricht 5 von 9
IMCornish
als Antwort auf: Anonymous
You hit the nail on the head, thank you. I was using a view template!
Andrew Robertson
Chartered Architect
Truro. UK
Nachricht 6 von 9
IMCornish
als Antwort auf: barthbradley
Thanks for responding but see my response to mpwuzhere above
Andrew Robertson
Chartered Architect
Truro. UK
Nachricht 7 von 9
IMCornish
als Antwort auf: ToanDN
Thanks again but no, I could not do it. But see the reply from mpwuzhere who got it right, I was using a view template.
Andrew Robertson
Chartered Architect
Truro. UK
Nachricht 8 von 9
tpuskas
How would you get it to show all 3 Options if you have 3?
Nachricht 9 von 9
als Antwort auf: tpuskas
Do you show all 3 options in one view?
