Hi there,
I have an issue when exporting an IFC - the facade, which is not a primary Design Option, doesn't show.
I am exporting "only elements visible in the view" and there is the desired option assigned to the view.
I have never had an issue exporting IFCs, with or without Design Options.
What am I missing here?
Thank you
Did you check the ifc export options to see if the design option includes any classes that may not be set to be exported?
It's a simple facade with just walls and doors - these are visible inside.
not export objects visibly in view.
Use active view when creating geometry.
