dernière version revit 2025 (2025.3) plantage Twinmotion-Latest version Revit 2025 (2025.3) Twinmotion crash
3 ANTWORTEN 3
Nachricht 1 von 4
vr04021980
328 Aufrufe, 3 Antworten
Bonjour,
Je travail sur la dernière version de Revit 2025.3 et je viens d'installer Twinmotion 2024.1.2 pour Revit.
Lorsque je suis sur Revit et que je sélectionne l'onglet Twinmotion intégrer directement dans 'Vue' et que je clic sur "Ouvrir dans Twinmotion"  = Revit plante.
Je viens d'installer la dernière mise à jour Revit 3.0 disponible sur le site autodesk.
Merci d'avance pour votre aide
I am working with the latest version of Revit 2025.3 and I just installed Twinmotion 2024.1.2 for Revit.
When I am in Revit and select the Twinmotion tab integrated directly into 'View' and click on "Open in Twinmotion," Revit crashes.
I just installed the latest Revit update 3.0 available on the Autodesk website.
Thank you in advance for your help.
3 ANTWORTEN 3
Nachricht 2 von 4
jordan_bullock1
als Antwort auf: vr04021980
Hi vr04021980,
It sounds like Revit might be encountering a blockage or corruption when attempting to execute the export to Twinmotion. Sometimes, issues like these can occur due to conflicts in the installation or residual files from previous versions.
1. Clean Uninstall and Reinstall of Revit:
To address this, a clean uninstall and reinstall of Revit may help resolve any underlying corruption. Autodesk provides a detailed guide on performing a clean uninstall to ensure all related files are removed before reinstalling: How to Complete a Clean Uninstall of Revit Products.
2. Workaround Option:
As a workaround, you could start directly in Twinmotion 2024. Open Twinmotion, then go to File > Import, and select the Direct Link tab. From there, you should be able to choose Revit as the source and pull the model from Revit into Twinmotion directly. I attached some snippets below to show this as well.
Something to also watch for is you must be in a view to successfully import or export information over to Twinmotion, so just be sure to check what tab is active in Revit! :lächelndes_Gesicht_mit_lächelnden_Augen:
Let me know if this helps, and feel free to ask any questions!
JORDAN BULLOCK
Autodesk Certified Instructor
Technical Specialist & Implementation Consultant
Nachricht 3 von 4
vr04021980
Thank you for your quick response. I uninstalled Twinmotion and reinstalled it in the folder suggested by the installation process. It is now working perfectly. During the first installation, I had changed the default installation directory, which caused the problem.
Nachricht 4 von 4
vr04021980
als Antwort auf: jordan_bullock1
