Is printing to PDF with depth cueing functional in 2020?
https://forums.autodesk.com/t5/revit-architecture-forum/depth-cueing-problems-on-pdf/td-p/7069430
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
@ChrisGamble wrote:Is printing to PDF with depth cueing functional in 2020?
It is here. What's happening at your end?
I don't have 2020 yet, but I was just curious because if you look at that link you'll see the issue is when views have depth cueing applied, and you print to pdf, the whole view becomes light gray in the pdf, even though it shows correctly in revit. Those post were from 2017, and im in 2019 and its still an issue.
why does the print doesnt come as per light weight after depth cueing, everything comes light
