Deployment - Batch Script
3 REPLIES 3
1362 Views, 3 Replies
I'm trying to use the sample script for single network license located at - Script
The script says it's for AutoCad even though it's located under the Revit section of the Wiki. Does anyone know how I can modify this to work with Revit? Something like substitue "acad" with "revit," maybe?
Thank you very much!
3 REPLIES 3
DannyHubbard
DannyHubbard
Yes this works with Revit, only thing you really have to change is the ACAD: to RAC2013: then your install directory.
Something like:
<mediaDriveLetter>\setup.exe /t /qb /language <lang> /c RAC2013: INSTALLDIR="%programFiles%\Autodesk\Revit Architecture 2013" ACADSERIALPREFIX=<SerialPrefix>ACADSERIALNUMBER=<SerialPostFix> ADLM_PRODKEY=<ProdKey> ADLM_EULA_COUNTRY=<eula_lang> InstallLevel=5 ACADSTANDALONENETWORKTYPE="3" ACADLICENSESERVERTYPE="Single Server License" ACADLICENSETYPE="Network License" ACADSERVERPATH="<FlexLicenseServer> 000000000000
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Something like:
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
in reply to: DannyHubbard
Thanks for replying!
I made the suggested changes and I recieved the same results. I've attached the log files but here is the part that fails -
MSI (s) (4C:24) [13:39:18:758]: Product: Revit Architecture 2013 - - Error 1606.Could not access network location Revit Architecture 2013\.
MSI (s) (4C:24) [13:39:18:758]: Note: 1: 1606 2: Revit Architecture 2013\
Action ended 13:39:18: CostFinalize. Return value 3.
Action ended 13:39:18: INSTALL. Return value 3.
I tried manually creating the program files directory then running the batch file but that didn't work. Any other suggestions? Thanks!
DannyHubbard
DannyHubbard
So your command string should look like the following, with the correct serial numbers and license server name.
\\192.168.1.105\InstallPoint\Autodesk_Revit_Architecture_2013_English_Win_32bit-64bit\setup.exe /t /qb /w /language en-us /c RAC2013: INSTALLDIR="%programFiles%\Autodesk\Revit Architecture 2013" ACADSERIALPREFIX=341 ACADSERIALNUMBER=12345678 ADLM_PRODKEY=240E1 ADLM_EULA_COUNTRY=US InstallLevel=5 ACADSTANDALONENETWORKTYPE="3" ACADLICENSESERVERTYPE="Single Server License" ACADLICENSETYPE="Network License" ACADSERVERPATH="licensesrv 000000000000"
Are you running this through a batch file? Did you right click on the batch file and use the Run as Administrator option?
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
