Demolished shading in section
8 ANTWORTEN 8
Nachricht 1 von 9
RobDBrown
346 Aufrufe, 8 Antworten
Seems like a simple enough solution but I cannot get the shading for the floor and Structural framing beam to be the same weight
Any ideas would be appreciated.
Rob
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: RobDBrown
Show your Phasing Graphic Overrides.
Nachricht 3 von 9
RobDBrown
als Antwort auf: ToanDN
Both cut and projection lines in Demolished are set to the same weight ?
Nachricht 4 von 9
Can you share the file here?
Nachricht 5 von 9
RobDBrown
Here you go
Nachricht 6 von 9
Set the Floors category's cut pattern to solid white instead of invisible.
Nachricht 7 von 9
RobDBrown
Thank you for the solution however i don't understand why this setting shouldn't also apply to structural framing however it works with the fill hidden for that element ?
Although it seems to solve the issue it isn't ideal when using a black blackground for drafting in Revit. (see screenshot)
Do you have any other ideas on why this is happening ?
Nachricht 8 von 9
No I don't.  If you don't want to use the solid while cut pattern for the walls then create parts from the walls and set the view to show parts.
Nachricht 9 von 9
I understand why.  It's all about Hierarchy. Your View Template Category Overrides are "fighting" Phase Filter Graphic Overrides.  You can do away with VT Category Overrides and just use a Selection Set Filter to get to where you want to go.
Help | Element Visibility Override Hierarchy | Autodesk
