Demolished Phase Cut Pattern Showing Different On Furniture Than On Walls
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
skyeg321
160 Aufrufe, 2 Antworten
Weird problem. We have all these lockers that are being demo'ed (yellow) but they aren't showing up with the line pattern override like expected. They have the pattern override but for some reason the pattern is too course. So with lockers being as small as they are it doesn't show as dashed. I made a test locker oversized to show this (pink) as you can see it has the dashed lines visible when the family is bigger. So to fix this I tried using a tighter line pattern for my phase override (green) but what is weird is this pattern is not affecting the lockers even though it is working on the walls (blues). So why would a graphic override only affect walls but not furniture? I just want my line pattern tighter on the lockers so the spaces show up.
2 ANTWORTEN 2
Nachricht 2 von 3
skyeg321
als Antwort auf: skyeg321
I figured it out partially. The lockers are controlled by the projection line override even though they are 7' tall and the cut plane is at 4'. So I had to change that too.
Nachricht 3 von 3
Furniture category is not cutable, so the pattern you see is the projection
pattern, not cut pattern.
If you want true cut patterns then use generic models or casework category.
