The demo wall is not displaying correctly. How to use the "Demo" hammer, or get the wall on the correct Phase, so that it displays as demolished?
Gelöst! Gehe zur Lösung
Gelöst von SteveKStafford. Gehe zur Lösung
What phase filter are you using?
If you change it to show Demo + New, it should display the demo as hidden line as display in the phasing setting.
Also do you have any override filter? This will override whatever that was display with phase filter setting.
The post I am posting is check those setting and see if you have item that deviate from the default setting. This will cause your demo wall to show as solid instead of hidden.
Upload the file so we can take a look closely.
A wall that has been demolished has the following settings: Phase Created "an earlier phase" and Phase Demolished "a later phase". The view that shows the demolished wall must be assigned to a phase that is later than when the wall was created. The Phase Filter should be one that is set to New (By Category) Existing (Overridden) Temporary (Not Shown) and Demo (Overridden).
Steve Stafford
