Demo infill display
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
gblack
1493 Aufrufe, 3 Antworten
Demo infill display
Is there a way to display infill (portion of a wall removed in previous phase) to define it's extents without showing new walls shaded? eg. we only see a line on each side of the wall. Could this be displayed as a rectangle with four sides instead of two?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: gblack
Use Unjoin Geometry button and select the infill wall.
Nachricht 3 von 4
als Antwort auf: ToanDN
I got a different take on this.
Reduce Far Clip.
Show Previous+Demo.
Change the Cut Pattern for Demolished (under Phasing Graphic Overrides) to Visible and White Solid Fill.
Nachricht 4 von 4
gblack
als Antwort auf: barthbradley
Thanks for the solutions. They work well. I also discovered if I break the infill element in parts it solves the problem as well.
