i have demolished a door which in turn creates an infill wall. technically that infill wall is new construction. but when i am in a view where the PHASE is set to NEW CONSTRUCTION the infill wall shows up as existing. is there something i am missing to get the infill wall to show as new construction on the NEW CONSTRUCTION PHASE?
Make sure the door was created in the Existing Phase, demo'd on the New Construction Phase.
Make sure/double check the View's Phase is set to New Construction, and the Phase Filter is set to "Show Previous and New", or also try "Show Complete" and see what the results are.
An infill doesn't have Phase/Phase Filter properties. Are you saying the infill in showing these properties?
