Dell XPS 15 9550 ( 4k )for REvit
2 ANTWORTEN 2
Nachricht 1 von 3
1152 Aufrufe, 2 Antworten
Hi, I have been having graphics issue with my XPS 15 9550 when I install revit on it. the font sizes are small and non readable and I tried changing the resolution to 175%. when I set in on 200% print options don't work. is it true that Revit is not compatible with 4k laptops. what are my options if I need a powerful laptop for Revit rendering.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Reduce the resolution to 2.5K @ 150%.
Nachricht 3 von 3
  • Make sure that graphic drivers are updated.
  • Make sure that the graphic card should be compatible with application you are using.
  • Your revit software tool should be updated.
  • For more graphic and resolution support check Dell XPS 15 Manual
