Deleting Viewports through copying and pasting objects into a new project
2 ANTWORTEN 2
Nachricht 1 von 3
350 Aufrufe, 2 Antworten
I'm having a few issues with Revit related to viewports. I have several on a document with several drafting views and sheets. I've found the only way to eliminate viewports at all is to copy and paste the drawings into a new project. However, if I do this individually it seems that viewports are tied to certain drawings so at first it may seem like I've eliminated all of them, but as I go through pasting they all slowly appear again. (Even if I've copied them all in the same default viewport in the original document). Is there a way to sever this connection? (Delete viewports and prevent them from being carried into a new project?)
Additionally, for some reason I can only copy by hitting ctrl+copy, not from hitting the copy button on the control ribbon. This makes it so I can't use "paste in same place" on the control ribbon.
Any advice?
2 ANTWORTEN 2
Nachricht 2 von 3
cbcarch
als Antwort auf: Anonymous
Not sure exactly what the question is, but--
With the pyRevit add-in, Wipe Tool--you can Fix Unpurgable Viewport Types
https://eirannejad.github.io/pyRevit/pyrevit/update/2018/01/01/45final.html
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 3
I'm confused. A sheet viewport is just a window through which you can see the actual view.  What are you trying to do?
