Deleting C:>Autodesk>WI>Autodesk Revit 2019
2 ANTWORTEN 2
Nachricht 1 von 3
skyeg321
869 Aufrufe, 2 Antworten
I am trying to create space on my machine. Does anyone know if deleting this folder will be a bad idea? I have all my projects sand families in a separate location and am only using 2020 now.
2 ANTWORTEN 2
Nachricht 2 von 3
RobDraw
als Antwort auf: skyeg321
Apparently, your computer thinks it's a bad idea.
Do you know that you should uninstall programs, not just delete the folders?
Rob
Nachricht 3 von 3
Matt__W
@skyeg321 rather than delete it, personally, I prefer to move the entire C:\Autodesk folder to an external hard drive. That way I still have the install files in the event I need to reinstall the software for whatever reason. The other alternative is to simply re-download the installation files to reinstall.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
