I found a mess in a project file. The room finish schedule has 15 "101 Lobby" and 12 different room numbers of "105" with different names. just to name a few. I asked the user if he deleted the rooms or just deleted the tag and he said he deleted the room and not just the tag. I tried it and he was right. I deleted a room "109 Toilet" and added the room back in and now I have 2 "109 Toilet" in the room finish schedule. How do I only display the current Rooms? Using Revit Architecture 2017.
Thank you.
Kory Skoog
CAD/BIM Manager
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Redundant Rooms should have No Area or Not Placed reported in schedule. See below:
Kory: I’m probably telling you nothing you don’t already know by now, but thought I jump in and reiterate Toan’s point (and one of my frustrations).
It’s all about the Room Schedule.
It frustrates me to no end that deleting a room in Revit doesn’t actually remove the room from the project (which I suspect the “other” guy thought he did). There is so much more, seemingly needless acrobatics involved. You need to create and work through a Room Schedule in order to accomplish any after-the-fact modifications and management. Because of this, I don’t know why Revit doesn’t just automatically create a Room Schedule once you start defining rooms in the project - since it certainly seems to reference one behind the scene.
With that said; I’m done. Hopefully this comment is on point and helpful. It’s all about the Room Schedule.
Cheers and good luck.
You can use Dynamo to do that, here is a video explaining how to do that and you can download the script as well: https://www.youtube.com/watch?v=YIyXzqar2TI
