Delete unused Filled Region
Message 1 of 9
Hi, How do I delete unused Filled Region from my Revit project?
Thanks in Advance
Replies (8)
Message 2 of 9
Additional Info:
When I command Drafting>Sketch>Filled Region and thenclicked Region Property, I see region Types with name associated to the inserted CAD File and it's a long list of them. It's this ones I am trying to delete.
Filled regions under the options are fine.
Message 3 of 9
Goto project browser - Families - Detail Items - Filled Region - Delete at
will
Nic Maes
wrote in message news:5137202@discussion.autodesk.com...
Additional Info:
Message 4 of 9
That's it. Thank you.
Message 5 of 9
While Revit still can`t find unused hatches by itself you can install HatchKit Add-in and delete manually all unused patterns (there is also a "purge" button for this purpose but it didn`t work properly for me)
https://apps.autodesk.com/RVT/en/Detail/Index?id=3030278704485778018&appLang=en&os=Win64
Message 6 of 9
Where do you get the "Delete at Will" command?
Susan
Message 7 of 9
martijn_pater
lol, that's hilarious (but just in case you are serious :|, just right click the one you want to delete --> delete)
Message 8 of 9
_Vijay
I like to use Dynamo such as processs.
Message 9 of 9
audrey
I just repurpose them to filled regions that I might use. Just workaround.
