Delete the Import Categories in Revit
3 ANTWORTEN 3
Nachricht 1 von 4
BIMAbhi
1639 Aufrufe, 3 Antworten
We can't delete some Import categories (from visibility Settings > Import Categories) after deleting the link from the manage link tab in Revit interface. Is ther any process to do this, please share.
Thanks & Regards
BIMAbhi
3 ANTWORTEN 3
Nachricht 2 von 4
GHASEM_ARIYANI
als Antwort auf: BIMAbhi
hi
I did not understand you??
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
Nachricht 3 von 4
ennujozlagam
hi, try to double check if the import categories is link or import. check every view. hope it helps. thanks
Nachricht 4 von 4
als Antwort auf: ennujozlagam
Thanks ennujozlagam, had the same issue today and you helped me realize my dwg was imported and not linked. Really wished I knew who did this!
I couldn't finish checking each of my views to find it though, since there were too many! Even if the dwg was in a view, I might have missed it if it sit underneath something else or outside of the view's crop boundaries...
For those having the same problem, I found the answer from this discussion on very same topic:
Anyway, does anyone know how to do this without resorting to DWG Explorer? This plugin works great, but I would prefer having its functionalities in Revit itself ...
