delete temp files?
2 ANTWORTEN 2
Nachricht 1 von 3
9396 Aufrufe, 2 Antworten
delete temp files?
Currently Revit caches model files to the local My Documents folder which eventually fills up the hard disk. It would be nice to have built in functionality that deletes files older than x days, or if there is a different solution to this problem, what is it?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Just time to time delete them....
Same with C:\Users\<username>\AppData\Local\Autodesk\Revit\Autodesk Revit 20XX\Journals
and
C:\Users\<username>\AppData\Local\Temp
Nachricht 3 von 3
Use Notepad to create a .bat file contains the following code:
forfiles /p "C:\test" /m "*.*" /c "cmd /c del @Anonymous" /D -7
C: is the target drive letter
\test is the target folder
/D -7 is for files older than 7 days
