Delete/Remove Browser Organizations
14 ANTWORTEN 14
GELÖST
Nachricht 1 von 15
2459 Aufrufe, 14 Antworten
I would like to delete several duplicated browser organizations I have transferred between files.  It seems the delete button within this dialog is grayed out and does not function.
How can I remove duplicated or unwanted browser organization types from my files. Any help is much appreciated.
Thank you!
14 ANTWORTEN 14
Nachricht 2 von 15
als Antwort auf: Anonymous
Try selecting something
Nachricht 3 von 15
als Antwort auf: barthbradley
Selecting something does not enable me to delete it
Nachricht 4 von 15
Alan.johnson1970
Have you tried applying one of the schemes (tick)
select one you want to delete (not tick)
AJ.
Nachricht 5 von 15
Make sure the Project Browser workset is not owned by anyone.
Nachricht 6 von 15
als Antwort auf: ToanDN
My Browser Organization is non-editable and not owned by anyone.  My inability to delete any browser organizations crosses into my sheets and schedule tabs as well, so I do believe it is being controlled by some global setting.
Nachricht 7 von 15
Maybe it was created by the Template (RTE) that you used?
Nachricht 8 von 15
Open the central file detached and try again.
Nachricht 9 von 15
Highlight it...don't checkbox it.  Whatever is checkbox'd cannot be deleted as it is the active scheme.
Also....if this was a central file, did you detach from central first?
Nachricht 10 von 15
Nachricht 11 von 15
Weird...mine the delete grays out when it is selected.  I can edit or rename but Delete cannot be selected.
I'm using 2019.2...what version are you using?  Checked...my 2020 doesn't allow me to delete active view schemes either.
Nachricht 12 von 15
I see.  I was on 2016.
Nachricht 13 von 15
This solved my problem, thank you.  I am still unable to delete the 'all' browser organization however.
Nachricht 14 von 15
"All" is read-only.  You cannot delete it.
Nachricht 15 von 15
mmartag
I have the same problem. and i haven't figure it out yet either.
