Delete Identical Instances all at once
joshmorgado
joshmorgado
How can I delete these warnings all at once? Why does Revit not have a select all button?
I have over 1000 warnings that I don't want to click on individually to delete. Can someone provide a solution? Maybe dynamo?
ennujozlagam
https://forums.autodesk.com/t5/revit-architecture-forum/locate-and-delete-identical-instances-in-a-p...
https://forums.autodesk.com/t5/revit-architecture-forum/delete-overlapping-duplicate-objects/td-p/35...
joshmorgado
Looking for an efficient way to delete these errors. There's thousands of them.
Niko_Davydov
The best approach for this is definitely Dynamo. You can quickly remove them all that way. Here are a couple of links to the Dynamo forum where this topic has already been discussed.
How Revit recognizes and indexs Duplicate? - Revit - Dynamo (dynamobim.com)
Extract Warnings using Dynamo - Revit - Dynamo (dynamobim.com)
Best regards,
Nikolai Davydov
joshmorgado
First Discussion Resolved my Issue thank you.
