delete elements
delete elements
delete elements
IS it possible to delete lot of element 1 by 1 but without preselection of them ?
i'm looking for somethink like 1 click on element = delete element.
It can be a macro , addin, plugin doent matter just i try to find some similar and i cant :X
Please help me with this request :?
www.TechRoom.bg
I dont know about plugin, macro , addon and .. and ... i prefer to use simple solutions 🙂
If i understand you right your problem can be fix easy.
Press Delete button and hold it down !!!
Than select items which you need to remove.
This will alow you to remove items by clicking of every single element without requesting approval (like BOX Do you realy need to delete .... ?)
I hope this will help
Good luck
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
This work well.
Thank you
