Default setting for copying
4 ANTWORTEN 4
Nachricht 1 von 5
dk-tradserv
403 Aufrufe, 4 Antworten
Is it possible to save the copy settings? Even if the programme is opened again
4 ANTWORTEN 4
Nachricht 2 von 5
GustavoUbriaco
als Antwort auf: dk-tradserv
Hi! do you mean copy monitor copy options?
Gustavo Ubriaco Contreras
Nachricht 3 von 5
ennujozlagam
your question is not clear? anyways if you want to copy settings? open the two files together go to manage > transfer project standard. thanks
Nachricht 4 von 5
By changing settings in the Revit.ini file, you can define software defaults that suit your needs or cause other changes in behavior to support your preferred workflow.
Drill down from this link to learn more:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2020/EN...
Nachricht 5 von 5
dk-tradserv
als Antwort auf: barthbradley
Than you for the information. I try it....
