Default Project browser width
2 ANTWORTEN 2
Nachricht 1 von 3
Prvoime
308 Aufrufe, 2 Antworten
Every time I open any file this is how my Project browser looks. This is the edge of the screen, it's not a cropped photo.
Is there some ini file I can edit to make it wider by default? Small nuisance, but if I can avoid expanding it every time I open something, it would be nice.
2 ANTWORTEN 2
Nachricht 2 von 3
kostask_oionei
als Antwort auf: Prvoime
Do you use double monitors? The revit window is maximize?
It looks like display settings problem.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
Nachricht 3 von 3
Prvoime
als Antwort auf: kostask_oionei
Single monitor. Window is maximized.
Doubt it has anything to do with display settings since Revit is the only program with the issue. Furthermore, Project browser is the only one that defaults to this narrow state, Properties palette stays whatever width I set it.
Found this thread, seems like Revit has issues with palette widths since forever.
https://www.revitforum.org/node/41348/page6
