Default number of workshared model backups
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
tim_mcguire
524 Aufrufe, 2 Antworten
The ohter day it was noticed that several views had been deleted from a model. No sweat we'll just open a backup copy and recreate the views right? Wrong. The workshared model is only saving 1 backup. When I go to save as....options... the number of backups is by default 1 not 10+. I do a save as and resave the model as central change the number of backups and repeat the process, sure enough the number of backups says 1 again when you go into the save as options. WTF. How can I make sure what the actual number of backups being created is? Thanks for the help and apologize if this has been covered before I did use the search funtion to no avail.
2 ANTWORTEN 2
Nachricht 2 von 3
RDAOU
als Antwort auf: tim_mcguire
@tim_mcguire
That of the local is inherited from the central...If it is workshared on the local network, doing the following should set/reset the max number of backups (
  1. Make sure all synced and relinquished -
  2. open the Central with create a new local unchecked
  3. Save As
  4. Go to option > change from 1 to 20 or 30
  5. Check the box make central (do not change name, overwrite the previous)
  6. Save
  7. Close >> Reopen central and check the max number of backups (should it be 20 now, create a new local and check that)
NOTE: The rational breakdown of 20 backups on workshared project is equivalent to an average of 4 users saving 5 times a day (or a similar ratio). ie: with  20 backups you  can potentially rollback to any previous save during that day only (not even the previous day). If your intent to is to roll back to a version from a previous week or some 2-3 days back 20 backups are as good as 1
When worksharing on a local network, your BIM manager should be backing up the central on a weekly or biweekly basis (not only relying on the automatic backups)
Nachricht 3 von 3
tim_mcguire
Great!!! Thanks RDAOU.
