I work 50/50 Revit and Civil 3D, so I am often linking DWG data into my Revit. I almost always want the same link settings -- units in feet, don't correct lines, don't orient to view, use shared coordinates, that sort of thing.
Is there a way to set these by default? I have to do this every time I restart Revit.
Whoa, never would have thought to do that. Thanks so much!
EDIT: hmm... actually, no. I just took my project, linked a DWG using the settings I want, then saved it as an RTE.
Restarted Revit, created a new project using my new RTE, and the link settings reverted back factory.
Link settings revert when I restart Revit.
Yep. You're right. Defaults are reset upon closing and opening new session of Revit. Maybe you can modify defaults through the Revit INI file. Have a look and see.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-9ECD669E-81D3-43E5-9970-9FA1C38E8507
Ah, the Revit.ini file -- a new one for me. I'll dive into that. Thanks.
