default family template file invalid
2 ANTWORTEN 2
Nachricht 1 von 3
467 Aufrufe, 2 Antworten
all attempts to use doors, windows etc. result in the message : The path you have specified for the default family  template files is invalid".  When installing Revit 2017 LT i did not specify anything.... the installer did what the installer did.   When I double click : Autodesk REvit LT Content Libraries 2017 and go to "Add or Remove Files".... the Content Pack comes up empty (according to the Autodesk website, I should be getting options here).
WTF?
thanks
James
2 ANTWORTEN 2
Nachricht 2 von 3
Xhenyth
als Antwort auf: Anonymous
Hi. It is likely that the error occurs for an incorrect software installation or movement / removal of the default folder. One possible solution is to go to the program symbol> Options> File Locations> Default path for family template files. Check that the path is the same as you like path where the files are located regards Juan Sarmiento
Juan Ramón Sarmiento
BIM Modeler / CAD Expert
Proyectista en ingeniería estructural
Nachricht 3 von 3
ennujozlagam
@Anonymous hello,, yo can try to check it HERE. thanks
