Hi
How to design a decorative wall based on a geometric shape? The attachment file is an example just to learning I want to do it something like the photos, I mean mirroring the shape and copy it or array it with space in between. Can I receive a step by step answer?
Thank you
Gelöst! Gehe zur Lösung
Great Question,
There are a few ways you could create a screen with the pyramid shape you attached. You could create the panel/wall in the concept massing environment, divide the surface using Triangle, create the shape you need as a generic pattern based family and apply the family to the divided surface. Load into your project and there you have it, if you have several 'panels just copy the family multiple times.
Using this method you would get a panel like the attachments...
Modify the pattern based family to how you like, this family can flex the height so you can create and interesting panel, but depends how you want your geometry...
Alternatively you'd model in-place if it was a single screen, if it's many screens then the above process is best
Hope this helps
For including geometric patterns on the walls, you can use various geometric shapes mentioned in the designs section. For the design you mentioned, you can use various shapes like triangle, borders, rectangle, etc, to make such wall designing.
Hi.Thank you for your reply. How to do it step by step please if possible?
