my client wanted stained wood slats as mounting surface for several small shop logos in a mall. The Problem is that I can not use decals (right side).
For the time being I made do with solid surface (wood pattern) on the left.
- Without actually making extra panel with exact dimension for each logos (they get changed very often), is there a trick to mount these on the array of these slats ?
