decal not showing in rendering
6 ANTWORTEN 6
Nachricht 1 von 7
1642 Aufrufe, 6 Antworten
Help! My decal is not showing in my rendering but it is showing in the realistic view...
any tips?
thankyou
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
what file type is decal?  Are you seeing its border in rendering?  What version of Revit?
Nachricht 3 von 7
als Antwort auf: barthbradley
I added 2 decal images (both jpeg)
the one on the wall is showing but I added one on the ceiling as well and this one is rendering white.. I think the issue is that the decal is upside down because it's placed on a ceiling... But I don't know how to fix it.. I can't rotate it
It's Revit 2019
Nachricht 4 von 7
I just tested and can't replicate.  Did you select the right work plane/face?
Nachricht 5 von 7
Do you know if it's possible to decal on a ceiling?
I made a 3D view inside my project and placed the decal image on the ceiling ( the same way I used for the decal on the wall) so it actually shows on the realistic view but not in render mode..
Nachricht 6 von 7
I just tested.  Compound ceiling: Yes, both faces.  Basic Ceiling: No.
Note: Decals render when they are placed on topside of Basic Ceiling. A lot of good that does.  What was Autodesk thinking? Ha!
Nachricht 7 von 7
Did you get this resolved? I am having the same issue, both my decals and anything I painted do not appear in my enscape when I render. They all were showing up the day before. @Anonymous
