Decal visible in Opt A:
Decal not visible in Opt B.
any ideas?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
You are still in Design Option editing environment.
Create a dedicated view for each option and finish editing the option for the view (it should says Main model on the status bar) then you should see the decal.
So Decal is view specific? Want to use the same facade study sheet with multiple views, in elevation and perspective, to print off different design options successively. Is it better to have them all set up at the same time>
No decals are not view specific. Not sure where did you get it from.
Are you saying that I need to have static views for each option?
Can I do this in the view template or must I duplicate the actual views and create another sheet for the other option?
Duplicate actual views.
Why would you want to switch view template every time you show a different option, not to mention you may have different annotation for each option?
Do you know of a trick to duplicate a sheet and contained views quick? ![]()
Is it correct that I also have to use multiple view templates for this to work?
Creating static views for the options did not fix the issue of the decal displaying only in the primary option!
