Hi
I created Decal Type/add image for screen. then I Place Decal on screen surface as you can see as below:
But they did not show decal when I render.
How can I fix it?
So, let me see if I understand the question: you placed a decal that cannot be seen by you -- or us -- and you are wondering why it won't render?
roughly render and can see your decal image. try to install latest updates from autodesk and see if helps. thanks
I have no issue. Can you try and check if your decal is set to correct path. As well try isolate Decal and Imac and try rendering it. See if that decal shows up.
I test place decal on wall. It work but when I place on screen It's only white
