DBLink issue
DBLink issue
Message 1 of 8
DBLink issue
Hey
I'm trying to export to a access database, but i get a warning every time i try. I attached the warning .txt i get and a screenshot of the warning there comes up in revit.
Do anyone have an idea on how i can solve this??
Nichlas
Replies (7)
Message 2 of 8
Did you get the exported file?
Message 3 of 8
Hey.
I'm not 100% sure on what you mean.
I start with creating a new Access file, i have tried both .accdb and .mdb, and then i find it going troug the DB Link.
I do it like he does in this vidio: https://www.youtube.com/watch?v=myYo-9X7rUI
Message 4 of 8
Did you get the .mdb file after running DBLink? Warnings are not necessarily errors.
Message 5 of 8
No, i made them my self.
But i have tried both, make one before export, and create one trough DB Link.
DB Link don't make a file. When i run it.
Message 6 of 8
When i do run DBLink, revit also comes up with this warnings message:
"Create database failed.
Attempted to read or write protected memory. This is often an indication that other memory is corrupt."
Message 7 of 8
Did you follow the steps?
Add-Ins > DBLink > MS Access 2007 tab > [Select a new connection] > Export > Point to a write-able folder, enter the file name and Save?
Message 8 of 8
Yes i did. 🙂
I tried to use the Desktop folder, and some other folders, but without luck.
