DB Link for Revit 2019 Gives Memory Error
4 REPLIES 4
610 Views, 4 Replies
I manage to use DB Link for Revit 2019, but it constantly give the following error message. I have tried it with Excel, Access, I have given full permission to "Everyone" for files. But no luck? Is there anybody out there used DB Link for Revit 2019 successfully?
4 REPLIES 4
Well...depending on how you got it so fast..if someone just sent  you the files, make sure the DLL's in the add-ins folder are not security blocked by Windows.  Right click properties and there will be a security button at the bottom which will allow you to authorize the dll.
1. I did not get it from someone else or install and add-on after installing Revit. As I explained in my post, I installed Revit 2019 on my home PC through Application Manager and it appeared under the Add-ons tab. There are also many other add-ons other than DB-link
I have Revit 2019 installed on my office PC. But I have installed that Revit from Autodesk Web page by downloading the installer. So there are two ways of installing this product apparently and the former one install the add-ons.
2. As I explain in my post, you do not need the add-on for exporting to a database. It is already under the file-> export menu... "Add-on" and "file-> export menu" leads the same place. I do not understand the purpose of the add-on.
So, maybe you can try on your pc very quickly if it creates a similar issue. See the following youtube video that shows exporting to an Excel file:
https://www.youtube.com/watch?v=zDKfk5KC-A0
It has to be Revit 2019 tough.
Many thanks....
For the uninformed, this post is related to the post shown on This Link
I have student/academic license.
I would really appreciate if anybody can try on his/her PC to export to Excel file so that I can understand if it is smtg specific to my PC and my Revit.
I am trying to export my Revit Model to an Access or Excel database but Revit it crashes constantly.
I use File -> Export -> ODBC  and select Excel file to export as explained here:
(I have posted a similar message earlier but no response. Wanted to bring the post back to the attention of the community)
Forma Design Contest
