DB Link and linked files
1 ANTWORT 1
Nachricht 1 von 2
klausvm
284 Aufrufe, 1 Antwort
Hi
Is it possible to use DB Link to extract data from the main model and all the models I have linked in a project?
1 ANTWORT 1
Nachricht 2 von 2
nmarcelis
als Antwort auf: klausvm
The element ID in database must be unique. There is only one way to export all data of linked models in one database. You need to create one federated model, link files, bind them (convert linked models into a groups), and then export. But you will sometimes encounter problems at binding process.
So I prefer the following method 1 model : 1 database.
If this helped you, please accept this as a solution.
Revit Certified Professional Architecture, Structure and MEP.
