I have three datum levels not showing in one view. The top of foundation, bottom of foundation, and basement levels do not show on the east elevation view. They do show on the three section views I have and on the other 3 elevations.
I checked VG, toggled levels on/off still did not display
Verified they are inside crop region in all other views, and all at set to 3D in all other views
Tried propagating from west elevation to east elevation, still did not display
out of ideas, I'm missing something obvious
Keith
Hi @Anonymous
Congratulations on earning the rank of an Explorer in the Autodesk Community!
Levels/grids and sections are referred to as datums and have 2D as well as 3D extents.
If it is still not shown in any view, create a scope box for datums.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Good morning Viveka,
Sorry for the delayed response, I decided not to slow my progress in the project and live with the missing Datum. Today I opened a new project Residential-Default Template and realized the missing datum are part of the template, rather than something I did in my previous project. I did follow your suggestions by drawing a dummy wall system, drawing a scope box around it in the first floor floor plan switching to the west elevation view , adding the datum (temp) and selecting all in view, and changing the extents to scope box 1. Oddly all the datum disappeared. Not sure what happened????
In the end I simply deleted the three datum that don't appear in the east elevation view, and then redrew them. This solved the problem, now all datum appear in all elevation views. The root problem seems to be in the Residential-Default Template (2017 Version), and the quickest solution seems to be delete/redraw.
Thanks for your help.
Keith
Good morning ToanDN,
Sorry for not getting back to you sooner, I appreciate your assistance. I also had a suggestion from Viveka who suggested the same approach. I'm hoping you can see my response to her to avoid typing the same response twice. If you can't see my reply to her let me know and I will provide you more details.
Keith
