As an alternate method then, you can add this information to your Title Block Family. Create a new Generic Annotation Family, place a Label, and create a new Parameter using the button in the bottom left of that dialog. Customize it as needed and then load this into your Title Block Family. Create a new Type Parameter (it cannot be Shared) in your Title Block Family to control the Text of this Label. Finally, place an instance of the Generic Annotation, select it, click the little grey button to the right of that Parameter under Properties, and select the newly created Parameter to create a link.
Disadvantages of this method:
- You will have to repeat this if more than one Title Block Family is in use.
- You will have to create a dedicated Title Block Family Type for each Phase.
- This data is not accessible to the Project, meaning that it cannot be Scheduled or otherwise referenced.
Corey D.
──────────────────────────────────────────────────────────────────────⁞|⁞ Please use
.Accept as Solution and
Give Kudos as appropriate to further enhance these forums. Thank you!
