In Revit 2024.2 with the Autodesk managed version of the Datasmith exporter, we're not getting the metadata correctly exporting. We are only getting Category, Family and Type, ie:
<MetaData name="1be9e9a50f9e4b8cb228a59d16f2d93c_DATA" reference="Actor.1be9e9a50f9e4b8cb228a59d16f2d93c">
<KeyValueProperty name="Element*Category" type="String" val="Stairs"/>
<KeyValueProperty name="Element*Family" type="String" val="Assembled Stair"/>
<KeyValueProperty name="Element*Type" type="String" val="Stairs 1"/>
</MetaData>
I've double-checked the export configuration, but I can only select the parameter groups, not the individual parameters like we could in previous versions of the exporter:
Is there something obvious that I'm missing or that I need to check, or is this a bug/limitation of the current Datasmith exporter?
Gelöst! Gehe zur Lösung
Gelöst von ryan.lenihan. Gehe zur Lösung
Did you find something about that?
I´m starting a new defaut template and ctrl C CtrlV from my 3D Model and the exrpoting includes all metadatas. So, I don´t know whya, but maybe it´s some bug from another old versions...
At the time I ended up using RTV Xporter, as it's version of the datasmith exporter provided all metadata. It was either all (in RTV) or nothing (in the adsk exporter).
I then wrote a c# application to post process the datasmith files to remove the unrequired metadata.
I haven't checked in the latest patches, but I do see some changes have been made. I have another project coming where I need to export to unreal, so I'll find out all about it soon.
