Got this error message while trying to open Revit LT files that I know are not corrupted. I went to Windows Control Panel and went thru the "Repair Program" process, rebooted and still same problem. Revit LT was running file last night, but as I went to close out of the program for the night, Revit LT crashed a few seconds before it had finished saving down the file that was open.
Does anyone have words of wisdom to fix this, or do I need to do a clean re-install of the Revit LT.
Is this a workshared file? Do you see the same behavior on other machines?
Copy and rename a backup file (the filename will end in a bunch of numbers). Try opening that. If it opens successfully, then delete the old file.
