Darken Current Revision Cloud
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
kdaugherty7
563 Aufrufe, 4 Antworten
Hello all,
I can't seem to figure out a way to do this, so I thought I would ask here: Is there a way to darken the current revision cloud series and lighten the older revision clouds? I thought there might be a way to do this with filters, but it doesn't appear that is an option....I am currently using Revit 2020.
Thanks in advance!
4 ANTWORTEN 4
Nachricht 2 von 5
RDAOU
als Antwort auf: kdaugherty7
@kdaugherty7
I have always been doing it using dynamo to override the revision cloud graphics based on the value of Current Revision Issued parameter... I do not believe they added that option in Revit (to filter or Select all instances in project)
Nachricht 3 von 5
kdaugherty7
als Antwort auf: RDAOU
@RDAOU
That is a great idea that I hadn't even considered! Is that a Dynamo Script you created or did you find that online? I am not the best with creating in Dynamo...is that something you would mind sharing?
Nachricht 4 von 5
RDAOU
It's a basic graph which you can put together from ootb nodes and/or several custom ones which u can download
You should be able to find a similar one on dynamopremier learning modules or dynamobim forum
Nachricht 5 von 5
BIM-CONG
It's a good way that @RDAOU said, there is also another way that you could try. Save the selection of the Revision Clouds, which in the same Nuberic(Or just one version of it) after creating them, and use selection filter to override the color in VV.
CONG XU
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
- BIM THE FUTURE -
