I have problems with the connection to CYPE software.
I need to connect with CYPE Arquimedes for quantifications and Revit always shows the same problem.
Hi @jfh12001
Welcome to the community! thanks for posting on our forum!: smileyhappy:
Your error message highlights the fact that the format is not supported.
The IFC format generated by Revit is the way in which the information introduced in a Revit project is transmitted to CYPECAD. See HERE for more information.
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
