CWS replacing glazed
noconnorG728Y
noconnorG728Y
**** this is hard to explain. I am working on a CWS in Revit. I created a curtain wall system and replaced the glazed panel with Louvre panel per the image. So when I am cutting the CWS to allow door ope that is host on a 175mm Insulated Wall being seen. I can cut/split the top part of the panel (of CW) and replace both with Louvre panel. So when I do it with the bottom part of the panel, I can only get close (off by 40mm) in order to cutsplit the panel and replaced them. It works in some locations and not in some locations. Any idea why it work and doesn't work? I am getting so frustrated trying to finish the CWS.
Any suggestion would greatly be appreciated....Thank in advance.
Looks like it could be fixed by changing the mullion profile (e.g. how it's draw in relation to the Origin Ref. Plane).  Maybe by unticking Adjust for Mullion Size.  Dunno. Can you post the **** file?  😉
