I'm relatively new to using Revit, and I'm encountering an issue with a wall.
The desired configuration for the wall is as follows:
I'm attempting to remove the red section. Currently, I've utilized the "Cut profile" feature within the view, but it isn't cutting in 3D or other sections as intended.
I experimented with the "Wall reveal," which has improved the appearance slightly, but it's still not exactly how I'd like it to be.
Is there a way to modify the reveal so that it resembles the first picture?
Alternatively, do you know of a better method to achieve this look consistently in 3D and across all sections? I've attempted to edit the profile, but it doesn't appear to be effective.
Thanks in advance!
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Edit Profile of Wall.
...actually, I'm not clear what I'm looking at or what exactly you are trying to do. Can you screenshot showing this wall in 3D View?
Edit Profile of the wall and draw the shape (it is different than Cut Profile).
Draw a roof and attach Top of the Wall to it.
Part of the reason for my confusion is that you mentioned Cut Profile. That's a view-specific detailing tool.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
Hello again, Thank you all for your responses.
I think I might have phrased it wrong. Here is a picture in 3D of what I meant:
I've tried the 'edit profile' in all different positions, but I'm not getting anywhere."
Just in Section View or do you want to Model it. If Model, Wall Sweep would work.
Help | Add a Wall Sweep | Autodesk
Using Cut Profile tool:
Its actually exactly like the wall sweep function. I'm trying to make it work, but probably need some help from youtube.
I knew the cut profile function. But it doesn't show in 3D, therefor i can't really use it.
Thank you alot sir!
