cutting topography
mina_saracoglu
cutting topography
mina_saracoglu
How can I modify my topography? I need to adjust and cut 4 contour lines in this area. Could you guide me? Thank you!
RDAOU
@mina_saracoglu
I do not have your version here to open and I am not sure exactly of the nature/reason of the modification you are doing (wrong points vs grading) but you can use
  • Modify Sub Elements (To modify points)
  • Or under massing and Site (Grade Regions)
Adittionally, that pixelated effect of contour lines happens when the DWG Topo is underlaying the solid topo. To make your life easier, go to visibility graphics and switch off the DWG (you no longer need it)
Edit: in conjunction with your other post on model performance, this is for instance a DWG which you no longer need and should simply remove it or unload it from view
handjonathan
Hi @mina_saracoglu
Thanks a lot for posting your question to the forums!   Has the solution suggested by @RDAOU helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
