I'm looking for some advice on how to cut the topography out of a parking garage entrance ramp. I'm using a building pad to cut the topography out of the parking garage itself that is under the building. The issue is that there is a portion of the ramp that is covered by earth, so I need to find a way to cut the earth out of the ramp, but keep the earth above it. I guess I'm trying to create a tunnel of sorts. This is also an issue at one end of the parking garage, as the parking area exceeds the footprint of the building above, so a portion of the parking garage will be covered with earth.
Creating a building pad doesn't create a tunnel through the earth; it creates a 'hole' if you will, unless I'm mis-understanding how to use this tool. I have a cast-in-place concrete entrance into the basement level parking that is below grade, so I need the earth cut out of the vehicle entrance but need it to remain above, as this will be a grassed area at this stage.
Create two toposurfaces as shown. The thing is this only works when you are NOT cutting though the tunnel.
...also, if you have full Revit (not LT), you could use Dynamo to create a Variable Thickness Floor from a Toposurface and then cut the Floor with an In-Place Void -- or create your "Topo" by shape-editing a Variable Thickness Floor using Modify Sub-Elements Tools (e.g. Add Points), and then cut the Floor with an In-Place Void.
If the whole issue is about the fill below the parking ramp...it is either to model in-place a generic model at that spot, give it earth material and name it "Parking Ramp Backfill"
Floor sub-elements are bugged...When one excessively fiddles with the sub elements of the Floor, one gets unpredictable/desired graphics in section views (check section 1 vs section 2 below). For some reason, since Revit 2016, the cut pattern of an adjusted floor slab tend to randomly change when the floor element is cut with a void...
ok, but how do I create another topography just above if the topography is complex? (see image) I have a ramp and several interior spaces at different heights and the land must be on top but obviously also at different heights. I don't know if I explain myself. I created some construction platforms and previously had the part corresponding to those interior spaces and divided ramps of the initial surface. When placed on top, the "construction platforms" are covered and it seems that the construction platforms have no effect. Please help
The attached screencast is an example of how you stack topo surfaces … keep in mind stacking works only for 3D (the tunnel will not be hollow if cut with a section/section box)
PS:
1. What @barthbradley is a more suitable method for your project.
2. the ideal option in my opinion is to regenerate the site/toposurface as a Mass (mass or generic model family)
Forum wont allow me to embed screencast!! here is the link https://autode.sk/39jiG6V
sc
What do you mean or how could you regenerate the site / surface as a mass? Right now I have the topography, do you mean turn the topography into mass and empty the tunnel?
Yeah that's what I meant...After looking at the images you posted, your model gave the impression that it has to do with either mining or tunneling. Therefore, what @barthbradley suggested is more suitable than stacking toposurfaces I guess...
How to turn your whole topography into a geometry/element which can be cut using voids? Several ways to do it...
Could you pass me the dynamo file? (280614tf@gmail.com) I have used very little dynamo I am a beginner.
After doing dynamo could you use the topography as a real topography? Could you modify your points, make subregions or divisions to the surface?
I would never encourage anyone to have Topo and building in one model especially when its an infra/tunnels/bridges/... But if it is a must or for the sake of experimenting, one doesn't really need to completely get rid of the toposurface! it can always be kept in the model, diced and sliced with a slim poch deth to serve as a land cover which one can host your soft/hard scape if one is a fan of entourage families and Revit's site designer... when done, all you need is to re-run and the mass element will re-adjust.
This diagram only looks at the topo surface and it doesn't take the tunnel into consideration. Anyhow, it is a workflow, massing the site is a solution to one problem but it will trigger a new question on a new problem to solve
