Cutting Openings in Walls
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
1070 Aufrufe, 4 Antworten
I have been following a tutorial about wall modifying. I noticed, it seemed that to add openings into a curved wall, you use "modify wall / wall opening", but you can't use this to work with straight wall, because "wall opening" is gray when you pick a straight wall, it seems you can only use "edit profile" to cut openings in a straight wall. Am I right? Thanks!
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Nope.  Wall Opening can cut straight or curved walls.
Nachricht 3 von 5
als Antwort auf: ToanDN
But whenever I click a straight wall, the wall opening button is grey out, I am using 2016 version, so what has happened ?
Nachricht 4 von 5
Don't highlight the wall.  Click on the Wall Opening tool on the Ribbon first, then select the wall to cut.
Nachricht 5 von 5
sounds like the wall's profile is edited. Access wall opening tool from Architectural tab instead.
