cutting a wall sweep on an angle for a gable roof
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
James_lB2
413 Aufrufe, 3 Antworten
Hi all,
I am attempting to model a weatherboard wall into a model with a gable roof. I cant figure out a way to cut through the sweeps when the profile of the gable roof begins.
I have modelled the last two 'panels' as stand alone model objects as a sweep rather than apart of the wall setup but how would I cut the geometry in a way that follows the shape of the roof? Photos are below.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: James_lB2
Use an in place void family to cut, or an in place solid mass to cut.
Nachricht 3 von 4
syman2000
Instead of sweep, I would use reveal. When you attached to the roof, the wall will follow the profile of the roof. See attached
Nachricht 4 von 4
James_lB2
als Antwort auf: syman2000
That looks great, thanks. Will definitely check it out
