CutePDF wont create pdf in Revit
s3855986
s3855986
Community Visitor
Community Visitor
Please help! I've installed 'CutePDF Writer' on to my PC. I set up everything in order to print in Revit but when I click 'print', no pdf is created, nothing actually happens. Does anyone know what I can do to fix this??
ralphdenhaan
I don't know much about this issue, but why dont you try PDFcreator from PDFforge? I use this for many years now without any problems.
https://lazybim.com/export-pdf-from-revit/
Maybe you can try this workaround: Go to print preview and try to print from there?
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
HVAC-Novice
use the native export to PDF option
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
