Cut void with void?
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
arma0404
377 Aufrufe, 10 Antworten
Cut void with void?
Hi everyone,
This might be simpler to resolve than I’m imagining, but I need to cut this void geometry at a 45° angle.
The profile of this void geometry is defined from the side, so adjusting the extrusion directly isn’t an option.
Since voids don’t cut other voids, I can’t create another void extrusion to achieve this 45° angle.
Are there any other solutions?
Beschriftungen (1)
10 ANTWORTEN 10
Nachricht 2 von 11
azad.Nanva
als Antwort auf: arma0404
if you share your family maybe can find better way.
if i was , i prefer to use the void Revolve as example:
Nachricht 3 von 11
arma0404
Thanks for the video! I'm trying to understand how your parameters work, but I'm not sure what's going on.
I attached my family to this message.
Thanks again!
Nachricht 4 von 11
azad.Nanva
what do you want do with this void , give me the big picture of your final work !
Nachricht 5 von 11
arma0404
als Antwort auf: azad.Nanva
I need to slope a wall family, and I can't use the "edit profile" function because I have to slope the side of the wall and not the face.
The only way I found was to create a void family and then cut the geometry in the main model.
Is it the right approach?
Thank you again
Nachricht 6 von 11
constantin.stroescu
have a look at my screencast
Constantin Stroescu
Nachricht 7 von 11
Constantin Stroescu
Nachricht 8 von 11
azad.Nanva
not really good one
you say side of wall , side in plan or side in elevation or section along the wall which one ?for slope in the wall or any element in revit we have another way, you see a way for top and base in @constantin.stroescu video.but if you want to cut in other sides (left or right) or (in or out).i be glad to help.
Nachricht 9 von 11
arma0404
Thank you so much for all the help guys.
My struggle here is that I would like the wall to adjust to the profile, but it can apparently only attach to one line at the time.
How do I shape it in a way where only one side of the wall slopes?
I attached a video of me trying out your suggestions.
Thanks again.
Nachricht 10 von 11
azad.Nanva
this is something else, now i understand what do you want .
Of course, if it's me i make the wall trim family with correct void for the wall.
Nachricht 11 von 11
azad.Nanva
what is your revit Version ? 2024
