Cut Void through topography
12 ANTWORTEN 12
Nachricht 1 von 13
4695 Aufrufe, 12 Antworten
I am looking to cut a tunnel through a mound I created in revit. The void should cut through where I have indicated in the image attached. I can't use dynamo so this won't be an option for me. Does anyone have any ideas?
Thanks in advance!
12 ANTWORTEN 12
Nachricht 2 von 13
hmunsell
als Antwort auf: Anonymous
use split Surface and delete/Hide the circle.
Howard Munsell
Nachricht 3 von 13
als Antwort auf: hmunsell
Thanks for the response. but this only applies to a horizontal plane, and I need to do it vertically.
Nachricht 4 von 13
hmunsell
please explain? don't understand what you mean needs to be cut vertically.
Howard Munsell
Nachricht 5 von 13
Unfortunately, it isn't possible natively.  Howevever, if you can use Modify Sub Element tools to shape edit a Variable Thickness Floor to "look" like a Topography and then cut the Floor.
FYI: a Revit Toposurface is just that -- a SURFACE.  It has no depth; no mass.  What you see in cross-section is a poche.  The depth of the poche is set in the Site Settings dialog box.
Nachricht 6 von 13
als Antwort auf: barthbradley
Oh no I have spent all day placing these points manually with their heights as you can see in the image attached and now I would have to do the same for the floor... Is this the only option do you think?
Nachricht 7 von 13
You can use Dynamo to generate a mass from the topo and use a void form to cut through the mass.
Nachricht 8 von 13
I'm not sure it would be viable in your case, but another approach used, is to cut the Toposurface with a Building Pad and then place a "Earthen" Floor above the Building Pad.
Nachricht 9 von 13
constantin.stroescu
Have a look at this screencast made by Balkan Architect...they propose a good workaround that can solve this problem quite well:
https://www.youtube.com/watch?v=Pwz-TTOBjmk
Constantin Stroescu
Nachricht 10 von 13
I've used that approach as well. The only issue is that it doesn't remove the poche in cross-section.
Nachricht 11 von 13
RDAOU
@Anonymous
Surface has no thickness, it is not a mass and the poche base isn't either
Refer to the following post looks like your case: https://forums.autodesk.com/t5/revit-architecture-forum/earth-filling-the-plan/td-p/9260427
Nachricht 12 von 13
This is exactly what I am looking for but how does your topo surface have a mass?
Nachricht 13 von 13
Also, how did you cut the floor like this?
